BPV?
Old 11-20-2006, 01:08 AM
97stanger
97stanger's Avatar
Default BPV?
Hey guys, I am getting a SQ trim mongoose kit for my 97 gt this christmas with a boost pipe...one question...should i get a bpv or a blow off valve for this setup? what exactly do they do and should i get one?
97stanger is offline
Old 11-20-2006, 01:26 AM
ShadowDrake
ShadowDrake's Avatar
Default RE: BPV?
A BOV can be used with a blow-through MAF... it vents excess charged air into the atmosphere... You put it BEFORE the MAF.
A bypass valve has to be used with a suck-through MAF setup, it vents extra charged air back into the intake somewhere, usually just before the blower, it has to be AFTER the MAF though.
Difference: BOV vents un-metered air, BPV vents metered air, so it has to go back into the intake path somewhere.
Just choose one based on your MAF setup. A BOV makes that cool PSSHHTT sound, a BPV will make it too but it'll be much more quiet.
ShadowDrake is offline
Old 11-20-2006, 01:46 AM
97stanger
97stanger's Avatar
Default RE: BPV?
well do i need either with a SQ trim supercharger and a boostpipe?
Old 11-20-2006, 01:55 AM
97stanger
97stanger's Avatar
Default RE: BPV?
I'm hoping to make around 9 or 10 lbs and was just curious as to if i need a mini race bypass valve or not....
Old 11-20-2006, 10:17 AM
97stanger
97stanger's Avatar
Default RE: BPV?
15austin
10-19-2014 04:24 AM
xterm11
06-14-2011 07:29 AM
Svtwv
4 Cylinder NA and Turbo
15
02-07-2011 08:20 PM
turbo 2.8
05-05-2010 12:22 AM
97tunedmustang
03-09-2007 10:29 PM
Quick Reply: BPV?
