Reverse Glow gauges
Old 03-25-2007, 06:36 PM
97modifiedmustangGT
97modifiedmustangGT's Avatar
Default Reverse Glow gauges
For you guys who have aftermarket gauges how hard is it to install them. I have been reading a lot and they say it is difficult for someone who is not a really good machanical person. There seem to be a lot of little things you need to make sure you don't screw up like swapping over the needles. here is what i am getting http://elgauges.com/index.asp?PageAc...amp;ProdID=365
97modifiedmustangGT is offline
Old 03-25-2007, 06:48 PM
Tac2cul
Tac2cul's Avatar
Default RE: Reverse Glow gauges
if those are the ones your lookin at gettin they do not require removal of needles. They slip over the needles.
Its pretty easy to install. Find wire(blue/white on headlight switch on new edges) for dimm and use power from where ever you choose.
Tac2cul is offline
Old 03-25-2007, 09:17 PM
Zoie_daGT
Zoie_daGT's Avatar
I have ones that are very similar to them. Yes, I did have to be careful about the needles but, it was nothing rediculous. Americanmuscle.com has the ones that I got. Don't worry about it, you should be fine. Fairly easy install and looks great.
Zoie_daGT is offline
Old 03-25-2007, 10:35 PM
97modifiedmustangGT
Are the AM gauges the slip over ones too?? I looked those and these ones look similar but are way cheap. I don't care how cheap they are as long as they look like the description
Old 03-25-2007, 10:53 PM
bigjohnson4.6gt
bigjohnson4.6gt's Avatar
i got glow gauges off of ebay, it was $25 shipped to my house, and all it does is slip over your gauges, you plug in the wires ground one, and tap into a 12volt positive for the other, screw it back together and your good. It was very easy, and get ones off of ebay they are cheaper and work just as good, heres mine i havent gotten the night pics yet
bigjohnson4.6gt is offline
Old 03-26-2007, 12:05 AM
Zoie_daGT
Zoie_daGT's Avatar
The AM.com ones are slip over gauges. They just lay over the stock ones.
jwog666
12-27-2021 08:09 PM
andrew1969
16
01-08-2016 02:48 PM
foxdude
09-24-2015 08:45 PM
Pyrate Dave
09-10-2015 07:30 PM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: Reverse Glow gauges
