why does my car run hotter a lot hotter
Old 05-10-2007, 01:11 AM
stangdriver2007
stangdriver2007's Avatar
Default why does my car run hotter a lot hotter
when i am idling or city driving my car gets warm up to the L in NORMAL and when it hits the L the fan kicks in but when im driving down the road at like 45 or more crusing the guage stays on the R in NORMAL im getting worried that something major may be wrong pleae help me out o and the manifold is new the radiator is new and the thermostat is new
stangdriver2007 is offline
Old 05-10-2007, 01:13 AM
svt_97cobra
I ♥ Acer
svt_97cobra's Avatar
Default RE: why does my car run hotter a lot hotter
Try a cooler Lower Degreethermostat
svt_97cobra is offline
Old 05-10-2007, 01:15 AM
SINISTER
SINISTER's Avatar
Make sure you have coolant in there and it isn't getting low on you.
SINISTER is offline
Old 05-10-2007, 01:17 AM
ballbreaker
ballbreaker's Avatar
clean or replace the air filter? depends on which kind you have. might not be the problem though.
ballbreaker is offline
Old 05-10-2007, 01:25 AM
AmericanRicer87
AmericanRicer87's Avatar
If you aren't low on coolant, try replacing your thermostat and cleaning out your radiator by running hose water from in side the engine bay out, also do a coolant flush. If this doesn't help watch for bubbles in your coolant resevior while reving the engine. and when you change your oil put a little bit in a glass jar and make sure it isnt green. but i really think the first sentence will fix your problem
AmericanRicer87 is offline
Old 05-10-2007, 03:06 AM
Jexey
Jexey's Avatar
take apart your thermostat housing make sure that f'er is working correctly. Another good way to check is to feel the hose after driving her for a while and if it's not hot your tstat is screwed up.
I learned about this a while back so I could be wrong, be nice if someone could confirm this.
Jexey is offline
Old 05-10-2007, 05:17 AM
NeoTokyo
NeoTokyo's Avatar
There is a breather screw that you can remove by your intake, you need to remove that when adding new fluid, it will allow the fluid in and burps the system so you dont get pockets of air.
Going to a 180 degree T-stat is a good way to go also setting your fan hi-lo on switch 10 degree's cooler will help a lot as well.
NeoTokyo is offline
Old 05-10-2007, 09:12 AM
kast1376
kast1376's Avatar
See if there is anything obstructing your radiator as well. Stuff like bags can fly in there and wreak havoc with cooling.
kast1376 is offline
Old 05-10-2007, 09:56 AM
stangdriver2007
im not low on coolant and there are no bubbles the thermostat is new but i can get another and try it i did a coolant flush when i changed the radiator like 1 and a half months ago anything else and what in the world does a air filter have to do with getting hot i saw someone posted that anyways thanks for the help
djbigskrilla
09-20-2022 01:04 AM
jjwinel78
08-17-2015 03:34 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
PearlGenPu
08-12-2015 01:57 PM
Quick Reply: why does my car run hotter a lot hotter
