convertible top soaked inside help please quick
RE: convertible top soaked inside help please quick
Well atleast I dont feel bad then well what does eveybody do with the water just clean it out. I had a lot in there and then when I went to clean it out it was a little left in there maybe just hit the gas then brake then gas and brake it will go somewhere I guess.
well its not the window. I put a hose on it and found that its in each corner rear bottom of the top. I dont know how i going to fix it would prob be easier if it was the glass but I guess I will have to find a shop. what do u guys do when your leak. this is just a constant flow. I would cut a little hole in the vinyle inside but where would it go after that???????????????????????
got the same problem and will look into the clear-silicone application around the window. Driving a vert. stang is a great pleasure!! No way I`d trade my vert for a h-top besides, living in a dry climate (california) helps with this problem.
TfcCDR
09-14-2015 12:08 PM
