Clutch Install
Old 12-11-2007, 08:30 PM
97targa
97targa's Avatar
Default RE: Clutch Install
The hardest part is realigning the tranny to the engine. I did a cobra motor swap and it went in like butter. I just did a swap on a 69 Vette and I swore and busted my knuckles for 6hours just to align the input shaft! Just make sure the alignment tool is in right and not wobbling all around!!! The rest is fairly easy and just put the two most outer bolts back in your starter, ohh and unhook your positive terminal first!Working on your back is prob. the hardest oart so if you could get even the dumbest of friends to give you the needed tools, that will save you plenty of time and burns on your shoulder blades from sliding in and out from under your car. The trans. bracket makes it easy for removal and installation. Leave the trans. hooked to the crossmember and just unbolt the two bolts of the crossmember!
97targa is offline
Old 12-12-2007, 07:52 AM
1fstblckgt
I ♥ Acer
1fstblckgt's Avatar
I did mine on jack stands. [:'(]
1fstblckgt is offline
Old 12-13-2007, 12:39 AM
MustangChris04
MustangChris04's Avatar
ORIGINAL: 1fstblckgt
yea well I didnt even have to jack my car up...
MustangChris04 is offline
Old 12-13-2007, 01:20 AM
tbirdscwd
tbirdscwd's Avatar
ORIGINAL: MustangChris04
LOL Yeah, real men change clutches with all four tires on the ground.
tbirdscwd is offline
Old 12-13-2007, 08:04 AM
1fstblckgt
I ♥ Acer
1fstblckgt's Avatar
ORIGINAL: tbirdscwd
That's impossible, unless its a truck.
mtgldr
02-03-2024 09:00 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
raleigh05GTO
09-04-2015 07:09 AM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Clutch Install
