how to remove chip
how to remove chip
http://www.americanmuscle.com/sct-4-...uter-chip.html
i have this chip installed, how do i take it out, it was not put in by me so i have no idea, i need it removed to pass emissions b/c it is not allowing me to complete my run cycles any chip install/remove tutorials, i need this thing out soon! i dont even know where the ecu is or how to remove it
RE: how to remove chip
Take off the kick panel on the passenger side. Take the little screw out that holds the computer bracket on and pull the computer out. It'll be plugged in on the back side.
ORIGINAL: contentsunderpressur
ORIGINAL: jEEd
did that chip not come w/ a "reflash" tune (factory tune) ??
ORIGINAL: cliffyk
Withpiggyback "chips" (modules), the stock tune is not changed or removed from the PCM memory.
[/align]
[/align]The memory bankson the module are either "switched" so that they disablean internal PCM memory databank and overlay it with memory from the module--or--disable the entire onboard PROM and use the daughterboard code and data. This is done by using internal ROM/RAM enable/disable signals that are available on the daughterboard connector.
[/align]
[/align]The OEM tune just sits there unused, and it automatically enabled when the module is unplugged as the OP has done. This is arguably a better way to do it than completely reflashing the onboard EPROM...
[/align]
[/align]
ORIGINAL: darcnytemare
wow i had to read this like three times to really start a hint of understanding. now do all chips do that? or just his chip and the tune thats on it?
jwog666
12-27-2021 08:09 PM
