8 bolts or 6?
Old 12-28-2007, 10:46 AM
GhostRider02GT
GhostRider02GT's Avatar
Default RE: 8 bolts or 6?
ok, new insight, the clutch is a 10 spline. Its a 96-01 cobra upgrade clutch kit, 11" 03 cobra flywheel and clutch, so itll fit the 45 or 3650 trans which is a 10 spline unit, so the clutch will at least fit, IF my stock flywheel is not tore up, correct?
GhostRider02GT is offline
Old 12-28-2007, 11:12 AM
Quicktime_GT
Quicktime_GT's Avatar
yeah.. if its 10 spline it should work .. I used my stock flywheel with my centerforce DF and it feels fine... I didn't even have it re surfaced because the shops around here would have probably made it worse.. I just cleaned it off real good...
If your flywheel is cracked anywhere get rid of it though.. if you've drove your car very hard it will probably have heat spots (purple spots) here and there.. As long as its not cracked, and it doesn't shake when you take off now, you should be fine with the stock unit..
Don't forget to adjust your clutch cable after you get everything together
Quicktime_GT is offline
Old 12-28-2007, 11:37 AM
GhostRider02GT
yea, clutch cable, yipee....
GimpyHSHS
19
12-19-2023 01:12 PM
baddog671
07-26-2016 01:20 PM
2poor4u2
09-26-2015 11:08 AM
maestro1024
09-21-2015 02:40 PM
trashxtrash
09-20-2015 10:49 PM
Quick Reply: 8 bolts or 6?
