Gears
Old 10-10-2003, 08:41 PM
jonnieboy239
jonnieboy239's Avatar
Default Gears
If i have a completely stock 02 gt and i want to add either 3.55 or 3.73ring and pinion set. would i have to buy any other parts to enable this to work properly?
jonnieboy239 is offline
Old 10-10-2003, 11:44 PM
GSXRIntensity
GSXRIntensity's Avatar
Default Gears
Nope. Just get some Mobil1 or Royal Purple Max Gear (synthetic blends).
GSXRIntensity is offline
Old 10-13-2003, 01:40 PM
gdear66
gdear66's Avatar
Default Gears
Has anyone out there ever had a problem with the driveshaft not connecting with the pinion gear once a new set of gears are installed? </P>
If so, does this commonly happen?</P>
gdear66 is offline
Old 10-14-2003, 04:10 AM
GSXRIntensity
Default Gears
While you are under the car..get a an FRPP AL DS. They are COOOLLLL
Old 10-17-2003, 11:47 PM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
Default Gears
1 thing, dont get 3.55's, they are a waste considering stock is 3.27. If you dont wanna run 4.10's at least do 3.73's or 3.90's.
mdvaldosta is offline
Old 10-17-2003, 11:50 PM
n2o44
n2o44's Avatar
Default Gears
</P>
are you refering to the flange that goes onto the pinion gear itself? or the drive shaft bolting onto this shaft? if its the last i have never seen this . <IMG src=smileys/smiley3.gif border="0"></P>
n2o44 is offline
Thunderball
15
11-22-2015 11:49 PM
Bokeo
10-10-2015 08:28 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: Gears
