Installing further mods
RE: Installing further mods
If you had it can tuned and put it on a dyno, you are fine.
You may be leaving some HP on the table, but they would have told you if your A/F ratio was messed up and in danger of damaging your car when you put it on the dyno.
ORIGINAL: 19sickgt98
I do know a stock 99-04 puts down exactly 231 RWHP, but im my stang i smoke those things pretty bad (lightly modded one's). Actually i put down 260RWHP with my DIRTY K&N filter and some messed up mufflers... And i actually bought the car modded already (previous owner was getting it ready for a supercharger). Before the tune i did not even know that i had a pi swap, people at the Dyno told me about it. But the motor looks bone stock with the exception of CAI and bullitt throttle body...
ORIGINAL: tws1098
yeah w/ those mods it seems odd that you would be making 260 at the wheels...most of what you listed shouldn't put you higher than a stock 99-04 which is like 230ish at the wheels
ORIGINAL: Mjaga251
Are you sure it's 260 Rwhp? I thought that was at the crank? Unless there's something I didn't know about a PI swap in the non-new edge?
New edges have 260 hp at the crank, stock. To the wheels, it's much less.
well, i have listed them... I make 260 rwhp
a npi stang (96-98) with a PI Swap makes more hp than a new edge stang because the pistons are different, which ends up changing the compression. with my mods listed below I make 244rwhp, however; I also have an auto, if I had a manual I'd be putting down 260-265rwhp. it is fun racing new edge stangs and winning .
I also beat the 05-08's...................... v6's [:@]
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
