tko 600???
tko 600???
saturday i went to the strip and on my first pass of the day i ripped 2nd gear out. now im gettin a tko 600 and i was wondering where i could find a 26 spline clutch to fit it and will i need to replace the flywheel. i know i will need to get a driveshaft spacer, the reverse switch pigtail, clutch fork pivot ball, 1/8th inch lock washer, speed sensor plug kit and bellhousing. im gonna get a short throw and was wonderin what everybody thinks of the mgw's.
RE: tko 600???
you wont need a Flywheel... Get yours resurfaced while doing the swap. I went with the Centerforce Dual Friction Clutch, love it no problems at all... Call D&D they will get you everything you need.
RE: tko 600???
alright thanks guys but i think i think i changed my mind and get a 500 cause a friend of mine has a new spec stage 2 clutch that he is gonna give me so that way i can save 300 bucks
RE: tko 600???
ORIGINAL: 2000GT4.6
You don't want a 600 anyway, your car doesn't have the power to pull thru 1st gear like it should (for a good launch anyway). the 500 has a steeper 1st gear.
musnicki
09-23-2015 07:11 AM
