Question about my oil
So i use Royal Purple. i know ford recommends 5w20, but all i can find around my parts is 5w30. does it really make that much of a difference?...or should i really be using 5w20?
i live in MD if that helps.
RE: Question about my oil
The 5W represents the lower temperature range of the oil. In this case 5W maintains its' viscosity dow to -20 degrees F. The SAE table shows the 30 (you have 20) goes up to 32 degrees F so the 5W-20 is mainly a winter weight oil. For the spring and summer you are better off using 10W-30 at it range if from 0 to 110 degrees F. This is what I have in my stang now.
Hope I didn't confuse you.
Jag
Jag
I brought this question up to the dealer and they say that the parts in these motors have such small clearances they require 5-20 and using any other weight oil can void your warranty....don't know how true that is...but i would go with what the dealer reccommends in the owners manual.
I doubt the difference in 5w20 vs. 5w30 at operating temps is enough to harm these engines, especially considering the 4.6/5.4 were originally engineered using 5w30. I just use Motorcraft 5w20. It protects the engine well ( I have a third party lab used oil analysis to prove that ).
One more thing...if you use what Ford recommends and log your oil changes and keep receipts, that makes itabout impossible for them to deny a warranty claim for lack of maintenence.
ORIGINAL: jagsfan
Jag
Jag
There it is...[/align][/align][/align][/align][/align][/align]
