PI swap, fast help needed!!!!!
Hey guy, I bought a pair of PI heads on Ebay, saying that they were taken from a 02 Mustang, but when it was all put back together we notice that the 4 upper bolts that go onthe timing cover to the heads are two small for the heads, they need to be wider. At first, we thought that maybe they we would have to take the bolts form a PI version, but we ordered them from Ford and they are the same size as the one's a had on stock.Only thing left that we can think off isthat they were from a F-150 or Lightning truck. Does anyone know if the upper bolts of the timing cover of a F-150 o Lightning are wider than the Stang? Has this happened to anyone else? I really need the help, my car is just sitting around doind nothing
RE: PI swap, fast help needed!!!!!
Sounds like you have Windsor heads. Did your cam caps look different than the origanal ones? I used Windsor heads for my PI swap. You have to order 4 timing cover bolts from Ford. They're 10 mm instead of 8 mm Romeo bolts. Just tell Ford that you need bolts for a '00 GT instead. You'll be set. And congrats with the PI swap.
I just hope that your right because I'm pretty sure that the heads a have are romeo because the valve coverare the 13-14 bolt pattern. I'll go and check this out first thing tomorow. Thanks
Your right, mine are the Windsor heads. I'm heading out right now to find the 10mm bolts that i need. Thanks Chris98Gtand 96GT226410for your help. I'll be sure to give u the heads up when my car is finished.
Thanks
Thanks
2010 Blue Ball Award Recipient
Good job on doing everything yourself man.
I was proud with my single passenger side head replacement, I can't imagine the feeling I'd hvae if I had done something like a head/cam/intake upgrade.
Though, to consider the PI swap a cam job too might be cheating
ORIGINAL: 72MachOne99GT
IT WILL BE ALL WORTH IT!!!!!!!
ORIGINAL: simplyme0484
Thanks
Thanks
Congrats, I'm still taking mine apart. I've got to buy some more tools I need. Thank god for payday!!
Cannibal_carnies
03-02-2023 06:17 PM
