rack and pinion bushing
Old 04-21-2008, 01:09 PM
racemyski
racemyski's Avatar
Default RE: rack and pinion bushing
I have a similar problem, just waiting on the parts to get here. Check out this TSB and consider replacing the steering gear tube brackets. http://www.paladinmicro.com/PalMFrame00.htm?wks=rak
I didn't want to replace the rubber with rubber so I went with urethane. I ordered Energy Suspension bushings for my 02 GT vert. You want part number: 410103(R) The (R) is for Red. I think there is also a black part available.
I bought the bushings from Pep Boys for $12 but it was a special order item.
racemyski is offline
Old 04-21-2008, 03:41 PM
99BlackPonyGT
aka 'Negative Nancy'
99BlackPonyGT's Avatar
in that description it doesnt look like you need to do anythingexcept undo the bolt and pry the busing out and slide a new one in...am i missing something?
99BlackPonyGT is offline
Old 04-21-2008, 04:38 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
ORIGINAL: 99BlackPonyGT
[/align][/align]If you remove the "tube bracket" on both sides as described on my DIY Fix page (the above link) there will be enough room to get the rear bushing out without loosening or disconnecting anything else--it's tight but it can be done without a lot of hassle...[/align][/align]
cliffyk is offline
Old 04-21-2008, 05:20 PM
99BlackPonyGT
sorry to beat the topic so much, just wanna do it right....you're saying i can swap the bushings without disconnecting my outer tie rods and all that, just jack it up, unbolt that bolt, slide the tube out, replace bushings, slide tube back in, reconnect bolts?
Old 04-21-2008, 05:46 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Yes, on the driver's side you'll have to shift the rack upwards (it will move forward when you push it upward) to get the rear bushing out--I did not replace the bushings when I did mine, however I did have both front and rear bushings out...
cliffyk is offline
Old 04-21-2008, 05:48 PM
99BlackPonyGT
thanks man, saves me some time! i really dont know much about cars...im learning lol... im in school for this so i figure its time to start trying stuff on my own....its just damn hard having such a low car and not having the proper jack and not having any jackstands...i really appreciate the help man
Old 04-21-2008, 06:15 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
If there's a Harbor Freight store near you they have 3-ton jackstands on sale all the time (the regular price is pretty low) thay also have some decent floor jacks for $60 or so (the steel ones). I have one of their 2-1/4 ton steel jacks I've had fornearly 15years, it was $30 when I bought mine.[/align][/align]You will need jackstands to do the rack bushings safely, the floor jack will make things a lot easier (if the floor jack won't fit under the front cross member use the OEM jack to pick the car up a bit).[/align][/align]If you want to buy one floor jack that will last the rest of your life, get this puppy. I've had mine for4-1/2 years, it isa crackerjack jack...[/align]
cliffyk is offline
Old 04-21-2008, 06:47 PM
99BlackPonyGT
well i need to get a lowprofile jack...i have a cheap-o autozone one that barely works....car is so low that most jacks wont fit under it
i need to invest in something like this
Old 04-21-2008, 08:00 PM
tonys04gtcerce
tonys04gtcerce's Avatar
i did mine with the tie rods connected, i bought poly ones from autozone for 12-13 dollars.
tonys04gtcerce is offline
Old 04-21-2008, 08:23 PM
99BlackPonyGT
would i see any benefit with the aluminum over the poly?
mtgldr
02-03-2024 09:00 PM
baddog671
07-26-2016 01:20 PM
KingRando
10-02-2015 08:06 AM
Explosive
10-02-2015 07:45 AM
UrS4
09-30-2015 10:13 AM
Quick Reply: rack and pinion bushing
