180 degree thermostat install
Old 07-23-2008, 03:14 PM
MoKo_04GT
MoKo_04GT's Avatar
Default 180 degree thermostat install
lately its been retardedly hot here in oklahoma city....so last week i ordered a "jet" 180 degree t-stat (which ups has scheduled to arrive today), just to help my girl run a little cooler in this miserable heat.
i have never installed a t-stat before...but certainly it cant be TOO TOO hard. i was hoping that maybe someone that has installed one could help out with a small "how to" ...or if anyone possibly knows of a link to some install instructions?
if so please chime in!!
thank you
edit: sure do wish someone would get the search feature working again!! *SiGh*
MoKo_04GT is offline
Old 07-23-2008, 03:40 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Default RE: 180 degree thermostat install
With the engine cold pack an old towel, or a wad of paper towels, or best of all a couple disposable diapers, around the base of the thermostat housing. You will lose a small amount of coolant and packing it like that will minimise the mess.[/align][/align]Then just remove the two bolts and pop off the top part of the housing, have a helper hold the radiator hose vertically or tie it up to the hood or something (Iattach a small length of cord to the hood before I start so I can easily tie up the hose).[/align][/align]Pay attention to which way the t-stat goes (the "button" end goes toward the engine). The new thermostat should come with a gasket, so clean up the sealing surfaces and bolt it all back together.[/align][/align]Torque the bolts to 18 ft.lbs.[/align][/align]
cliffyk is offline
Old 07-23-2008, 03:43 PM
MoKo_04GT
MoKo_04GT's Avatar
cliffyk your help is greatly appreciated, sir!
just one last question...is the t-stat housing located kind of to the right of the plenum? im pretty sure i know where it is...just wanted to double check tho to be 100% sure.
Old 07-23-2008, 04:05 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
It's slightly in front of the driver's side cam cover, there's a 2" black hose connected to it; you cannot miss it...
cliffyk is offline
Old 07-23-2008, 04:18 PM
MoKo_04GT
MoKo_04GT's Avatar
ok thats what i was thinking. thank you for confirming.
also thank you for the write up/help...it is greatly appreciated, and is about to get put to good use within the next couple of hours.
Old 07-23-2008, 04:30 PM
MoKo_04GT
MoKo_04GT's Avatar
well....make that: put to good use right now....since it just arrived!!
thanks again cliffyk for the prompt response and info!
Old 07-23-2008, 04:44 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Make sure the engine is COLD. it takes 3-4 hours after shut down from hot for my '03 to get to the point where I'd be messing with the thermostat1st thing in the morning is better...
cliffyk is offline
Old 07-23-2008, 05:00 PM
MoKo_04GT
MoKo_04GT's Avatar
lol yeah i just went out there and i could feel the heat still coming off of the engine from a few hours ago....so....guess i will just wait untill morning. haha thanks
mtgldr
02-03-2024 09:00 PM
Nick Oliver
10-17-2018 04:22 AM
MusicCity615
09-12-2015 07:05 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Quick Reply: 180 degree thermostat install
