Changing Plugs and COPs
Old 04-29-2009, 06:50 PM
devongarver
devongarver's Avatar
Smile Changing Plugs and COPs
Hey, simple one here guys-
I found a cracked/damaged coil pack the other day(got my engine bay a little wet cleaning it) and this finally explains the entirely random suttle miss i would hear now and then. So i ordered a new set and i ordered some ngk tr55 plugs while i was at it. My car has 75k on it so i figured i might just as well change em all out. So my question is this, does anyone know what the tr-55s come gapped at? Is the factory something like 52 thousandths? i cant remember, i just want to double check before i do this tomorrow. Also, anything else i should check on while im in there? Keep in mind i have 75k on the clock. Any input would be appreciated! Thanks guys!
devongarver is offline
Old 04-30-2009, 12:31 AM
cbbass123
cbbass123's Avatar
plugs should already be gapped .54 but always recheck to make sure. And make sure you buy a decent gapper or at least not a flawed one. I bought a dollar gap key ring at autozone...It seemed odd that all my ngks were out of gap from box...then... i found my real another gapper that i used to use and apparently the autozone one was crap or at least the one i bought was flawed. The autozone i was gapping at .54 and checked with my good one and it was showing .65 N E ways, if your motor is a bit dirty...hit it up with a vacuum around the cops so crap don't fall in holes. Vacuum around cops...pull cop...then vacuum again and inside hole...then remove plug and replace
cbbass123 is offline
Old 04-30-2009, 03:46 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
...it is a popular misconception that plugs are pre-gapped from the factory,\...
From NGKs FAQ (click here)...
The factory spec for platinum plugs is 0.054", however if you are using conventional plugs I'd tighten that up a bit to 0.045" or so. The smaller tip of the platinum plugs allows the gap to ionise at lower voltages than the fat, square end of typical tungsten electrode plugs.
cliffyk is offline
Old 04-30-2009, 06:43 PM
devongarver
Question
Ruh roh....well i made sure they were gapped to .054 and installed them. The ones i installed were NGK TR55s. Should i have knocked it down to .045? Or am i ok since i used the NGKs?
Old 04-30-2009, 06:48 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
You're all set, I wouldn't take 'em out for that--when you get the blower you'll want to tighten up the gap...
cliffyk is offline
Old 04-30-2009, 06:50 PM
devongarver
Oh, phew! I was a little worried haha. Will these be a cold enough heat range to keep once i put the blower on? I kinda thought i would need to go a step colder...
Old 04-30-2009, 07:53 PM
grogan
grogan's Avatar
im running the ngk8s for 10 psi of boost
grogan is offline
Granatelli Sales
03-25-2016 08:01 PM
2007StangV6
01-28-2016 06:09 PM
Granatelli Sales
12-27-2015 06:28 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Changing Plugs and COPs
