Steering has some play
Old 04-30-2009, 11:48 AM
StangJunkie04
StangJunkie04's Avatar
Default Steering has some play
I recently installed a UPR tubular k-member with coilover setup w/ cc plates on my 04 GT, and got an alignment done. The car drives straight but i have noticed that there is some play in the steering wheel. I can move it side to side about 2-3 inches with out the steering reacting. I have checked the tie rod ball joints while up on jacks and there is no play. I am just wondering what else I should look at to take the slop out of the steering.
StangJunkie04 is offline
Old 04-30-2009, 11:59 AM
grogan
grogan's Avatar
im installing the same setup tomorrow and ill give an update if my wheel does the same.
grogan is offline
Old 04-30-2009, 01:57 PM
BraMas
BraMas's Avatar
Do you have headers on your car? Your rag joint in your steering stem probably needs to be replaced
BraMas is offline
Old 04-30-2009, 02:50 PM
StangJunkie04
yeah bbk LT headers
Old 04-30-2009, 02:56 PM
stangalator
stangalator's Avatar
mine does this a little too, maybe i should check mine out as well... I mean not a few inches, but it does it at higher speeds... it will start going to the right or left a little without any movement from the wheel...
What are signs that the rag joint is failing / how do i check to make sure its fine?
stangalator is offline
Old 04-30-2009, 04:04 PM
CrazyDan
CrazyDan's Avatar
I have the same kind of play as well. But haven't tackeled the problem yet. When I do I will have a write up with pics.
CrazyDan is offline
Old 04-30-2009, 04:23 PM
amoosenamedhank
amoosenamedhank's Avatar
You can either replace the rag joint or you can upgrade to a solid steering shaft.
http://www.stangsuspension.com/store...?idproduct=966
Or I guess you can replace the rag joint with a u-joint
http://www.jegs.com/i/Borgeson/153/034931/10002/-1#
I have the same problem with my mustang and I'm trying to decide which method to go after... I'm going to take the steering shaft back out and take a look at what would be involved in trying to swap the rag joint for a u joint but because that's about $140 dollars cheaper than buying a new steering shaft.
amoosenamedhank is offline
Old 04-30-2009, 05:33 PM
stangalator
any negative affects from upgrading to a solid rag joint, more road vibrations in the wheel maybe?
Old 04-30-2009, 08:36 PM
PaintballFreak
PaintballFreak's Avatar
your steering will be much tighter and more responsive but you will hear/feel chatter when cornering hard. Same as you would with aluminum rack bushings instead of poly ones
PaintballFreak is offline
Old 05-01-2009, 06:25 AM
StangJunkie04
hmmm... I will have to weigh my options.
lincolnshibuya
12-08-2020 01:49 PM
CS2007
06-25-2019 09:45 PM
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
ChampInSD
10-02-2015 04:55 AM
stark777
09-21-2015 12:46 PM
Quick Reply: Steering has some play
