a/c question
Old 07-22-2009, 11:31 AM
PROMETHEUS PRIME
PROMETHEUS PRIME's Avatar
Even if the compressor was bad when the coil is energized the clutch will or should engage and click. Jumping the hi and low switch you should see if there is power getting to the coil on the compressor. The connector with two wires in it. If theres now power there then it's not an electrical problem.
PROMETHEUS PRIME is offline
Old 07-22-2009, 10:32 PM
disturbdgt
disturbdgt's Avatar
so are you saying that if i jump the high and the low switches i can use a volt meter or something to check and see if there is power going to the compressor. so check the connector going to the compressor? or am i just misunderstanding you. I'm so confused right now, i just want my a/c back.
disturbdgt is offline
Old 07-22-2009, 10:53 PM
PROMETHEUS PRIME
YES. With the car on and ac turned on you can jump the cutoff switches and check for power at the compressor coil connector. if you have power there then you know it's failed compressor part or actual low freeon. in you don'[ have power then you know its electrical
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: a/c question
