Rebuild specs
Old 07-31-2009, 04:52 PM
  #31
SVTeeshirt
SVTeeshirt's Avatar
too legit, the promotion rebuilt ones use beefy shift forks (i think carbon fiber) syncros and a 26 spline input shaft.
they are good for 750hp.
SVTeeshirt is offline
Old 07-31-2009, 04:55 PM
  #32
disposablehero27
disposablehero27's Avatar
meant to ask you .. what do you mean about "Promotion Rebuilt" ones.. is that a company, or a brand.. kit... etc
disposablehero27 is offline
Old 07-31-2009, 05:27 PM
  #33
SVTeeshirt
SVTeeshirt's Avatar
its a company, they basically take old bellhousings and replace everything inside with fresh parts, and in some cases, stronger parts... much stronger.
http://www.promotionpowertrain.com/1231590.html
mid way down where it says 4.6 only.
Old 07-31-2009, 05:45 PM
  #34
disposablehero27
awesome good to know. so i've decided that i'm going to shoot for 500. good solid number right? how much of a pain would it be to swap 03 heads and put on my block? total pain, or just bolt right on? ...nothing is that easy right?
Old 08-01-2009, 02:12 AM
  #35
SVTeeshirt
SVTeeshirt's Avatar
bolt right on, but even used 03 heads cost a pretty penny.
If there is one good thing about the modular motors its that all heads are interchangable, even a 4v swap isn't THAT difficult.
Old 08-03-2009, 09:41 AM
  #36
disposablehero27
thats good to know, i'm picking the motor up tonight. long block $450. gettin ready to start the build. what do you guys think about boring it .30 over?
Old 08-03-2009, 11:51 AM
  #37
toolegit86
toolegit86's Avatar
ive heard of the promotion rebuilt set up i just like the 160+ mph
i think .30 over is around 3.5812 and thats fine. the stroker kits are bigger just get your pistons and send them in wiht the block and that makes sure that the pistons match.
toolegit86 is offline
Old 08-03-2009, 12:10 PM
  #38
disposablehero27
cool, sounds like a plan. so i'll get a stroker kit, would i have to have a different crank for that as well? if i went .30 over?
baddog671
07-26-2016 01:20 PM
robcy
Suspension
10-27-2015 11:14 PM
Dathan
10-05-2015 05:52 AM
Drastang
09-30-2015 03:48 AM
marc954
09-25-2015 06:48 AM
Quick Reply: Rebuild specs
