the 99 headlights v.s. 00-04 headlights
Old 08-27-2009, 10:23 PM
35thAnvMustang
35thAnvMustang's Avatar
Default the 99 headlights v.s. 00-04 headlights
im purchasing a set of headlights that came off of a 00-04 mustang and i was wondering if there is much of a difference and how much better they were than the 99. thank you
35thAnvMustang is offline
Old 08-27-2009, 10:26 PM
TheMustang
TheMustang's Avatar
Think they're just darker from 01-04. I upgraded my crappy chrome ones for some smoked ones off ebay for $100.
TheMustang is offline
Old 08-27-2009, 11:30 PM
35thAnvMustang
will the smoke ones be any clearer. mine are all hazy. i just want to be able to see at night
Old 08-28-2009, 12:12 AM
TheMustang
TheMustang's Avatar
Yes. Yes.
Old 08-28-2009, 01:17 AM
gunpig0313
gunpig0313's Avatar
The 99-00 were all chrome inside the 01-04 were black & chrome inside. You can go to Wal-mart and get a headlight cleaner kit for like 15, 20 bucks and they'll look like new again my buddy did it to his F-150 the other day looks good.
gunpig0313 is offline
Old 08-30-2009, 04:51 PM
1FINE99
1FINE99's Avatar
Post
Another way (and much cheaper) to fix the fogged lights is to start with 1000 grit paper to get the rough spots out and then go to 2000 and finally 3000 grit followed by the Meguires clear plastic polish.
Be sure and wet it down while you're sanding too. You'll only need one or two sheet of sandpaper each so don't but the 6pack cause you won't need it.
I just done this to my 99 GT vert and they look nearly new, 1000% better, all for about $7. If you have a rotary polisher - use it, the polishing will go faster. The sanding is short and sweet but the polishing took about 30 min to get the clarity I wanted.
1FINE99 is offline
Old 08-31-2009, 07:24 PM
pcs
pcs's Avatar
the smoked versions do look better imo though, but if you dont mind the chrome ones you can just clean them up as mentioned above. good luck
pcs is offline
StalkerGT
11-28-2015 03:09 PM
Seanam
10-04-2015 10:15 AM
Drastang
09-29-2015 03:31 PM
Mobiusone stang
09-07-2015 08:46 PM
amandahchase
09-03-2015 10:09 AM
Quick Reply: the 99 headlights v.s. 00-04 headlights
