I have a leaning problem, please help
Old 10-07-2009, 02:29 PM
shaggy rogers
shaggy rogers's Avatar
Default I have a leaning problem, please help
I have a 2000 mustang GT that is now about 3/8 of an inch lower on the driver side than the passenger side. This car has mostly all Steeda suspensions products including sport springs that were installed about 7 years ago. Although the problem just became noticable in the last few months I can't imagine the springs would already be worn out on the driver side. I also snapped a rear sway bar(after market) and none of this was during any recent track time, or performance driving(just going to work and back). I don't believe these two problems are related, and I have replaced the sway bar again but if the two are related I would hate to snap another.Does any one have any expiereince or advise. My local mechanic suggest removing the springs and have them compression tested at his shop, but that would be expensive if the springs shouldn't be shot already anyhow.
Thanks
shaggy rogers is offline
Old 10-07-2009, 02:33 PM
willydawadd
willydawadd's Avatar
i had a problem like this...quit letting fat chicks drive ur car, even if they put out
willydawadd is offline
Old 10-08-2009, 01:18 AM
masterofthepuppets99
masterofthepuppets99's Avatar
+1111111 lmao
masterofthepuppets99 is offline
Old 10-08-2009, 01:43 AM
Sxynerd
Sxynerd's Avatar
The high side spring isn't fully seated into the lower pocket and is lifting one side.
Sxynerd is offline
Old 10-08-2009, 01:55 AM
medrick
medrick's Avatar
sxynerd is prob right. is it the front or the rear of the car? if rear, unbolt the shocks from inside the trunk and jack up the car so the rear end will drop down freely. see if the spring ends are facing diferent ways. if they are adjust them to match then bolt it back up. if its the front, unbolt the strut and then jack up the car and let the suspension drop down. then turn the spring to where the end is in the deepst part of the control arm to "fully seat"
medrick is offline
Old 10-08-2009, 02:11 AM
Sxynerd
Sxynerd's Avatar
To give you an idea of how bad it looks.
Not seated correctly:
Seated Correctly:
Sxynerd is offline
Old 10-08-2009, 09:13 AM
shaggy rogers
Thank you I will give those sugestions a shot. I guess it is possible for the springs to have rotated or shifted after 7yrs? Maybe with hitting a signifiant bump in the road? Again thanks for the information.
Jb145700
08-21-2022 06:37 AM
Seanam
10-04-2015 10:15 AM
firecoyote
09-27-2015 02:37 PM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
Quick Reply: I have a leaning problem, please help
