Do i need camber plates for pro kit
Old 12-06-2009, 12:55 PM
saleen036
saleen036's Avatar
Default Do i need camber plates for pro kit
Hey will i need camber plates if i low my gt vert with pro kit? Will i need anything else or just the kit thanks
Travis
saleen036 is offline
Old 12-06-2009, 01:05 PM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
Seems to me the Pro Kit is about 1.5" drop, so generally not considered to be necessary. I think they are a good idea though, as you can square the tires up better for longer wear and add a bit of caster if you go wider wheels.
Jazzer
Jazzer The Cat is offline
Old 12-06-2009, 01:14 PM
mrtstang
mrtstang's Avatar
I've had the Pro Kit on for about 3 years now, and haven't had any problems. When i put it on i had it thrown on an alignment rack to make sure everything was good.
mrtstang is offline
Old 12-06-2009, 02:27 PM
jmac72187
corner carver
jmac72187's Avatar
Do you need them? Not necessarily.
Should you get them? Yes.
jmac72187 is offline
Old 12-06-2009, 03:07 PM
tdcalhoun89
tdcalhoun89's Avatar
yeap, I've had mine for a year now, haven't gotten around to them yet... I'm getting there though, if you have the money to do it when you do the springs might as well do it then
tdcalhoun89 is offline
Old 12-06-2009, 03:24 PM
saleen036
saleen036's Avatar
Perfect! thanks!
baddog671
07-26-2016 01:20 PM
jerrytubes
10-23-2015 12:11 PM
mdg
10-01-2015 07:04 AM
winner99
09-30-2015 07:04 PM
UrS4
09-30-2015 10:13 AM
Quick Reply: Do i need camber plates for pro kit
