stock manifold
Old 01-25-2010, 08:39 PM
Warrior1876
Warrior1876's Avatar
Default stock manifold
Can the stock manifold handle 20 psi of boost or does it need to be upgraded and which one do you recommend?
Warrior1876 is offline
Old 01-25-2010, 09:27 PM
liljojo4711
liljojo4711's Avatar
upgrade
liljojo4711 is offline
Old 01-25-2010, 09:43 PM
Warrior1876
Ok but upgrade to what. THanks
Old 01-25-2010, 10:07 PM
Z28KLR
Z28KLR's Avatar
Trick Flow and Professional Products make decent ones. I'm sure there are others out there I'm not thinking of.
Z28KLR is offline
Old 01-25-2010, 10:11 PM
ddmsgtr1
ddmsgtr1's Avatar
I'll be running the trickflow track heat eventually. For 20psi I'd consider running the oval tb style intake, you might get a decent gain with that kind of boost.
ddmsgtr1 is offline
Old 01-26-2010, 02:45 PM
Warrior1876
can i get away with stock for a while running 20 psi, i actually cracked my original intake because the car overheated but the new manifold is a plastic composit with i guess steel around the insert so it does not crack. Can i go with this for a wile or am i asking for it.
Old 01-26-2010, 03:04 PM
atrain59
atrain59's Avatar
Get this one from bbk [IMG][/IMG] Here is the link if you want to check it out http://www.bbkperformance.com/produc...-manifold.html
atrain59 is offline
Old 01-26-2010, 03:46 PM
ddmsgtr1
ddmsgtr1's Avatar
From what I've heard that's been in the works for a very long time. So long that most people will probably s**t their pants if it ever comes out.
ddmsgtr1 is offline
Old 01-26-2010, 03:52 PM
mrtstang
mrtstang's Avatar
I'm not sure what would be best, but i hear a lot of good things about the Eldelbrock intake.
mrtstang is offline
Old 01-26-2010, 10:23 PM
pcs
pcs's Avatar
well if you want to find out if the stock can handle 20psi the try it, what kind of f/i are you going to put on the car and what kind of short block are you using?
pcs is offline
Gene K
10-21-2015 11:37 PM
trashxtrash
09-20-2015 10:49 PM
uberstang1
09-20-2015 06:42 PM
ccdguy
09-19-2015 05:20 PM
dunebuggydude11
09-13-2015 03:03 PM
Quick Reply: stock manifold
