TC OFF button doesn't turn on after STS install
Old 01-30-2010, 12:58 PM
99GTvert
is my username.
99GTvert's Avatar
Default TC OFF button doesn't turn on after STS install
I installed my MGW a while ago, but after I plugged everything back in, the light on the TC button doesn't light up even after I push it to turn off TC. The car still has TC, it's just that I have to kind of guess if it's on or not....or spin a tire and find out that way.
Did I mess something up on the connection? Should I remove the stuff to get access to the plug and just clean it out or something?
99GTvert is offline
Old 01-30-2010, 01:22 PM
Z28KLR
Z28KLR's Avatar
You could try that, but my guess is the bulb in the switch is burnt out. I don't think they're replaceable, you may need to get a new switch. Now, my TC doesn't work (due to ABS issue) so I'm a little unsure, but, doesn't your car have a second TC indicator light in the instrument cluster in that row of idiot lights at the bottom? Mine does (green light, looks like a spinning tire), shouldn't it also light up to indicate if your TC is on?
Z28KLR is offline
Old 01-30-2010, 02:29 PM
99GTvert
is my username.
99GTvert's Avatar
My car has that second light, but it only lights up when the TC is "doing its thing" (like when I try to nail it in the rain from a dead stop). If yours stays lit when it's turned off or on, it's probably another thing that Ford changed when they gave the Mustang a little makeover in 2001.
99GTvert is offline
Old 01-30-2010, 04:24 PM
sweger
sweger's Avatar
yeah mine only lights up when i break em loose...the green one on the dash that is. im glad to, it would be annoying to have it on all the time.
sweger is offline
drfister
05-03-2018 10:38 PM
squishbang
12-04-2015 02:29 PM
MXBT187
08-20-2015 02:36 AM
dseg
AmericanMuscle.com
08-10-2015 03:29 PM
LaBelle
08-09-2015 07:05 PM
Quick Reply: TC OFF button doesn't turn on after STS install
