Anyone running Alloy USA 31-splines
I'm shopping for axles right now and wondering if anyone has had experience with alloy USA forged axles. The are much cheaper than mosers and come with lugs, bearings and seals
I had a pair of 28 spline axles that I installed a couple of summers ago. Needless to say they didn't want to come out when I had to have the rear redone in the December of that year. The driver side axle was spun into the carrier and the shop ended up cutting the carrier up with a torch.
Thanks,
I know the 28 splines are weak, which is why I'm swapping up to 31s. I'm just wondering if anyone has done a built 31-spline rear setup with these and had any problems with them.
Thanks for the input tho
broke my 28 spline stock axles about two years ago shopped around ended up byeing 31 spline alloys,had heads and cams and a 125 shot neaver had a problem with them used my nito out of the hole after that switched motors did compete forged under d-1 pro charger 14 lbs. of boost through a 200 shot on it axles are still there blew the hell out my motor going to put them under the test with my new build 5.4 trickflow heads comp stage three cams victer jr intake 12to1 comp, 200 shot hope for better results sold my d-1. lol.
Been running Alloy USA 31 spline axles for over 2 years without any problems!!
musnicki
09-23-2015 07:11 AM
09-10-2015 08:39 PM
