gauge question
Old 03-12-2010, 04:59 PM
budders
budders's Avatar
Default gauge question
Hey guys, im pretty when the gauges swipe on the s197 it means that the battery is low. The gauges swipe on my 99 on start up, does that mean i need a battery replacement? not sure if every body elses gauges swipe on startup either thats why im asking
budders is offline
Old 03-12-2010, 08:38 PM
CadenZ
CadenZ's Avatar
I always thought that the needles cycled when you started the engine. Than again the battery died recently...
CadenZ is offline
Old 03-13-2010, 01:02 AM
99gt302
99gt302's Avatar
My 99 does it after I unhook the battery, but not when I start it everyday.... so maybe your battery volts are dropping down and causing it.... you mite be right
99gt302 is offline
Old 03-13-2010, 08:28 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
It is not normal for the gauges to reset each time you start the car, as others have suggested it can be caused by a failing battery--check the battery voltage while cranking the engine, it should be greater than 10.5V. If less than the battery has a one or more weak cells and should be replaced.
One other thing to check is fuse 2.21, a 5A fuse in position 21 of the central junction box fuse panel, under the dash. This fuse supplies a constant +12V to the instrument cluster to maintain it's volatile RAM.
cliffyk is offline
Old 03-13-2010, 12:24 PM
budders
budders's Avatar
thanks cliffy!! you are the man. i will check the voltage upon cranking. and those fuses. it was raining the whole day before i started her up, so maybe a short of some sort? not sure though... but its raining again.. all day. so ill have to do it during the week sometime.
budders is offline
Old 03-14-2010, 12:30 AM
budders
budders's Avatar
how old was your bat?
budders is offline
SteelerNation82
09-16-2015 07:11 AM
MusicCity615
09-12-2015 07:05 AM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: gauge question
