06 GT Wheels on 99GT ? ?
Old 03-19-2010, 10:43 AM
Revvington
Revvington's Avatar
Exclamation 06 GT Wheels on 99GT ? ?
Hey All, my buddy has a 99GT and found a great deal on a set of 06 GT 17" OEM Bullit wheels, I know that the lug pattern is correct on it But I noticed that the tire size is diff ( 235/55/17 ) also I need to know if the lug pattern will work. Thanks alot! Also If you have pics of this done I would love to see how it looks!
Revvington is offline
Old 03-19-2010, 12:52 PM
B3ATNGU
B3ATNGU's Avatar
Yes they will work completely, only thing is you will sit higher from that 55 side wall. I unfortunately have these on the front of my stang only because at the time I didn't have money to buy some new ones so i got them used.
B3ATNGU is offline
Old 03-19-2010, 01:06 PM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
Correct
The tires are about 1.75" diameter larger then the OEM 25.6" diameter stockers. The wheels also tend to run about 5/8" additional negative off-set, so they will sit under the car about this much farther then on an S197. You may get some rubbing on sway bar and/or fender liner on that combo.
Jazzer
Jazzer The Cat is offline
jwog666
12-27-2021 08:09 PM
UrS4
10-03-2015 06:23 AM
mungodrums
09-28-2015 10:54 PM
folivier
09-26-2015 02:28 PM
lincolnshibuya
09-24-2015 10:46 PM
Quick Reply: 06 GT Wheels on 99GT ? ?
