steering squeal
Old 04-27-2010, 04:45 PM
allmotor
allmotor's Avatar
Default steering squeal
hey i have noticed that when i turn from a stand still, slow speed, and high speed that there is a loud squeal. Its coming from the front suspension. I am mostly sure it is not the tires so wondering if anyone has or had the same problem.
allmotor is offline
Old 04-27-2010, 05:24 PM
02stang2113
02stang2113's Avatar
Are the tires rubing with the wheel well?
02stang2113 is offline
Old 04-27-2010, 05:32 PM
allmotor
allmotor's Avatar
Default wheel well
I know when i bought he car it came with newer wheels that did rub the sway bars when fully turned because they are taller than stock but this happens when only slightly turned.
allmotor is offline
Old 04-29-2010, 05:15 PM
btbw92091
btbw92091's Avatar
maybe the surp belt is slipping when you put a load on the p/s pump???
btbw92091 is offline
Old 04-29-2010, 05:25 PM
FlamingoGT
FlamingoGT's Avatar
What kind of squeal? There is a TSB on something similar to this, but I don't remember how that sound is described (has to do with the mounts). Cliffy specifically addresses this issue on his website (paladinmicro.com??? somebody help me here )
FlamingoGT is offline
Old 04-29-2010, 05:30 PM
zero2005
zero2005's Avatar
probably the stock pump. i know mine does that. friend that has a v6 does same thing but WAAAY worse.
zero2005 is offline
Old 04-29-2010, 11:24 PM
jjandascog
jjandascog's Avatar
Check the ball joints and/or tie rod ends. Mine did the same thing and it was the ball joint, I had to buy a grease needle from Autozone to inject some grease in the joint (since we do not have zerk fittings).
There is also a TSB on rack mounts doing the same thing, they sell an updated part to stop the squeek
jjandascog is offline
Old 04-30-2010, 07:11 AM
devongarver
devongarver's Avatar
Click ME
devongarver is offline
Old 04-30-2010, 11:13 AM
zero2005
zero2005's Avatar
see, i think there may be more to it than that tho - as im runnin the QA1 tubular K, which replaces that whole design and integrates it into the k itself, and i still get the noise. its not a big issue for me, as i have other creaking issues going on.
zero2005 is offline
lincolnshibuya
12-08-2020 01:49 PM
CS2007
06-25-2019 09:45 PM
ChampInSD
10-02-2015 04:55 AM
allenmaty
09-24-2015 09:17 AM
stark777
09-21-2015 12:46 PM
Quick Reply: steering squeal
