What would happen if you were running 5 24lbs injecotrs and 3 19lbs injectors?
Old 05-07-2010, 06:58 PM
JC316
JC316's Avatar
Originally Posted by cliffyk
Unfortunately it's a somewhat confused guess, the injector pulse width has everthing to do with how much fuel is sprayed...
The PCM calulates a precisiely timed pulse each time the injector is commanded to inject fuel. The length of the pulse is based upon a whole things, however air flow as measured by the MAF, IAT, ECT, throttle position and what it knows about the injector capacity (from the low and high injector slope settings in the tune).
In closed loop operation the PCM also considers feedback from the front O2 sensors when calculating the injector pulse width.
OP, if you were to datalog your car you would like find that the fuel trims on each bank will be very different. The adaptive learning system can handle up to +/- 25% added or reduced fueling which makes it able to handle the 19lb/H and 24lb/H mix (barely).
But, it is not good. Do you know what the tune is set for (19 or 24)?
Are you sure they are yellow and not orange?
The tune is the stock GT, so it's for a 19lbs injector. They could be orange, I am color blind and I have issues between yellow, orange, and red. So basically, I need to grab some 19lbs injectors or get 24lbs injectors and a tune?
JC316 is offline
Old 05-07-2010, 08:02 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
That's it...
cliffyk is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
StalkerGT
09-25-2015 02:41 PM
MusicCity615
09-12-2015 07:05 AM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: What would happen if you were running 5 24lbs injecotrs and 3 19lbs injectors?
