Codes
Old 05-24-2010, 03:14 PM
gilly615
gilly615's Avatar
Default Codes
So my car is throwing the following codes:
P0135
P0155
I know that they are for the heater cicuit for sensor 1 on bank 1 and 2 and was wondering if the MIL eliminators that are on the car can cause them. The car is a 2004 gt with a mac mid pipe.
gilly615 is offline
Old 05-24-2010, 03:26 PM
BraMas
BraMas's Avatar
Your MILs should be on the 2nd set of O2's if your getting a code for Sensor 1 on bank 1 and 2 that means it is your first set of O2's that are throwing the codes
BraMas is offline
Old 05-24-2010, 04:24 PM
gilly615
gilly615's Avatar
The MIL eliminators are on the second set of sensors i'm just wondering because before I installed the eliminators iwas only throwing codes for the rear o2 sensors.
gilly615 is offline
Old 05-24-2010, 05:08 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Have you checked the 20A fuse in position 8 of the central junction box (under the dash)?
The heaters for all four O2 sensors are powered by that fuse; the PCM turns the heaters on by switching the "ground" lead...
cliffyk is offline
Old 05-24-2010, 06:35 PM
gilly615
gilly615's Avatar
I have't checked it yet. I have had the fuse blow a few time
due to a bad o2 sensor, which I've fixed and when that happened the car threw 7 codes all related to emmision components. I am leaning away from the fuse being blown.
gilly615 is offline
BOB ROME
07-26-2023 01:54 PM
mrtrodonet
09-19-2020 03:12 PM
lincolnshibuya
12-08-2015 04:37 PM
Dathan
10-05-2015 05:52 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: Codes
