Driver Side Window won't go down.
Old 07-17-2010, 09:06 PM
USMCSKYLINE
USMCSKYLINE's Avatar
Default Driver Side Window won't go down.
I was driving today and when I tried to roll down my driver side and passenger side window...both wouldn't go down. I go home and I tried again and this time the driver side window went down but the passenger side still doesn't.
what do you think is the problem?
I check the fuses inside the car but they're all good. is it the motor? (I've tried both the button in my driver side and the button on passenger side.) Also I don't hear the no noise coming from the passenger side like I did on the drivers side.
USMCSKYLINE is offline
Old 07-18-2010, 07:43 PM
zero2005
zero2005's Avatar
ok, i know you said you checked the fuses, but check the fuse panel under the steering wheel. there's a relay under there (i think its the only one? -- it should be the center position, the only one with pins?) it controls the motors i think -- as i have my panel off right now, and i have accidentally knocked it out and it kills both sides...
zero2005 is offline
bjdutch2005
03-24-2017 03:38 AM
Pyrate Dave
09-10-2015 07:30 PM
TimeLord101
09-04-2015 09:27 AM
amandahchase
09-03-2015 10:09 AM
Quick Reply: Driver Side Window won't go down.
