4.6 timing chain tensioners
Hey guys, i had a tensioner arm break i three spots on my 03 2v 4.6. I have abuilt bottom end, KB, billet oil pump. I'm thinking with my high oil pressure that my tensioner sees is causing it to extend further than normal. With the rachet system in the tensioner it isn't allowed to back off. I have heard some guys will grind a few teeth away on the tensioner that way the rachet sytem won't hold the that much tension on the chain. The tensioner was wearing into the aluminum on the tensioner arm so i was suspecting to much tension.
Has anyone heard about grinding some teeth away?
Can i just get rid of the rachet system? Will the chains get too loose without that stopper in when the car is shut off(no oil pressure)?
Thanks Darwin
Thanks Darwin
Thanks Darwin
Thanks Darwin
Where did you get the kit from? How does it work? Do you have a built engine? Does the pressure bleed off and loosen the chain too much? Thanks
I have not put it in the car yet.I got it from car quest box says pci. it had this paper in it. they look the same as the old ones from 2 feet away.
The Tensioner style may look different than your original style. This newer style was first introduced by Ford in the year 2000 on the 4.6L V-8 and continued through 2004 and perhaps further. It has performed well and makes the timing system installation a little easier. The earlier style is cast iron and has a ratchet system and pounting plate. We have adopted this newer style for all of our 4.6 and 5.4 V-8 engines and the 6.8L V-10 engines. During installation be sure to use a mounting plate under the Tensioner if the original style used one. If the original version did not use or need a plate under the Tensioner then one is not required. Oil pressuer leaks and improper Tensioner operation will occur if the plate was left out of an installation that requires one. It is up to the installer to be correct. -notice T65432-33 ford V-series
Thanks Darwin
Thanks Darwin
Also pressure comes from resistance to flow could something else be wrong and even without the ratchet system will stuff still break.....If your high pressure made it break maybe the ratchet system made it happen sooner but you are still going to be putting higher pressure on the chain and tensioner, Just a thought.
PS why do you have a high psi oil pump... do you NEED it. Sounds like the fix is getting rid of it...From what I have heard one only needs a high volume/pressure pumps if the motors clearances are more than factory specs if not then it’s not so needed
mungodrums
10-07-2015 04:01 AM
