97' Cobra Mustang won't start.
Old 09-30-2010, 11:58 PM
skidmark19
skidmark19's Avatar
Default 97' Cobra Mustang won't start.
I have searched old posts and read other groups and I must have a unique Cobra. I have owned 7 years and have not encountered this problem yet. Driving along at about 40 mph. All of a sudden no acceleration and car now decelerating. I have not checked fuel pressure yet, however I traced all vacuum lines and emmissions components and cleaned and made sure connection was good. Changed gas cap, and re-installed some of the many duplicate emmisins parts that I have and same thing. Pulled 3 plugs and checked and nothing out of ordinary. Does anyone have a vacuum hase diagram for a 96-98 Stang? Since the V-6, GT, and Cobra use same charcoal cannister hose routing must be the same. I don't think this is my problem because the hose that runs to the intake manifold has been undone in 2 places for at least as long as I have owned the car. Please post any info you feel will be useful to me. Thanks, Alan.
skidmark19 is offline
Old 10-01-2010, 12:16 AM
Synyster06Gates
Synyster06Gates's Avatar
If it stopped running and now it won't start, it sounds like fuel to me, either that or electrical.
Can you hear the pump prime when you turn they key on (don't crank it, though)
Synyster06Gates is offline
Old 10-01-2010, 12:30 AM
skidmark19
skidmark19's Avatar
Default It is getting fuel.
It does get fuel and spark. No error codes. Screwing with it for 4-5 weeks due to tight budget. While crawling around underneath I have found many more minor issues and repaired them. Just wont start. I did blow out a catalytic converter thru the exhaust. Is there a chance it could be causing a no start scenario?
Old 10-01-2010, 01:23 AM
JC316
JC316's Avatar
Absolutely it can be causing the no start. I was thinking clogged cats anyway. Still, check your fuel pressure, cheaper than exhaust. Just because it's getting fuel doesn't mean it's getting enough fuel.
JC316 is offline
Old 10-01-2010, 06:10 AM
uberstang1
Chupacabra
uberstang1's Avatar
Drop the mid pipe and try and start it. A vacum leak from something like the charcoal canister wouldn't cause this and besides a CEL you probably wouldn't even notice it.
uberstang1 is offline
Diode Dynamics
28
05-26-2022 12:02 PM
mstahoo
SVT Forums
08-19-2021 09:15 PM
KEM Motorworks
08-14-2015 10:13 PM
'stangdude
08-12-2015 01:27 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: 97' Cobra Mustang won't start.
