Idle question, 98 GT
Old 05-30-2011, 06:36 PM
Black_Growler
Black_Growler's Avatar
will a bad IAC cause some spudering at low rpm's in each gear as well along with the motor dying after I pull it out of 5th gear on the iState?
Black_Growler is offline
Old 05-31-2011, 04:17 PM
Z28KLR
Z28KLR's Avatar
Yes. But it could be a few other things too, like a vacuum leak or egr related. How does the car idle, just sitting?
Z28KLR is offline
Old 05-31-2011, 07:48 PM
Black_Growler
Rough. It'll drop to like 500 or a hair below then jump back up to between 750-1000rpm depeding if the a/c is on or not.
Old 06-01-2011, 08:02 AM
98redstang
98redstang's Avatar
iac and fuel filter perhaps... change the fuel filter if you havent and take the iac out and spray some carb cleaner in it and you should be good to go.
98redstang is offline
Old 06-02-2011, 09:29 AM
Black_Growler
Ok I'll give that a shoot! Thanks!!
2007StangV6
01-28-2016 06:09 PM
trashxtrash
09-20-2015 10:49 PM
2015Ecoboost
09-17-2015 01:48 PM
Scottyboy187
SVT Forums
09-13-2015 10:23 PM
96stang3.8
09-10-2015 06:42 AM
Quick Reply: Idle question, 98 GT
