02 mustang exhaust gasket
I am new to the site. And i just purchased my first mustang. I need some help.
Does the exhaust flange on the driver side require a dounut gasket. The passenger side I know has a flat looking flange gasket. But the two flanges look nothing a like and my driver side has no gasket and leaks bad.
The exhaust gasket is only on the passenger side. Do you have an aftermarket mid-pipe on your car? Just wondering, cause if you do, the person who owned the car before you may have cause the leak by not putting the mid-pipe on properly.
The driver's side has a ball & socket type joint, if tightening the nuts does not seal it up then whoever installed it might have left out the sizing insert that most all after market X and H-pipes come with. The 2-1/4" "ball" on the exhaust manifold does not mate with or seal well to the 2-1/2" socket on the aftermarket pipe, so a 2-1/4" short insert is provided to match them up.
You can see it in this photo from UPR's site:
interesting, so there is no exhaust gasket at the flange on the passenger side? I noticed that when they did my motor swap they used a red liquid sealant there and I thought they half assed it. I do have a passenger side exhaust leak that is driving me nuts and I suspect that is where it is coming from....there is no exhaust gasket there? how did ford seal it from the factory? I have stock exhaust...
thanks (again) cliff...
eastexsteve
3.7L V6 Technical Discussions
12-04-2015 05:41 AM
91StangOwner
08-20-2015 11:34 PM
KEM Motorworks
08-14-2015 10:13 PM
