how to rebuild front calipers
Old 10-18-2011, 05:20 PM
96meangreengt
96meangreengt's Avatar
Default how to rebuild front calipers
Hey guys I scored me a set of cobra front brakes for my gt and I noticed that one of the dust boots for one of the pistons has been ripped and the others look like they are dry rotted. So my question is have any of you rebuilt your calipers before. I have watched a couple of vids on youtube and it looks relatively easy but thought I would ask first. The local shop qouted me over $200 to rebuild them which is ridiculous.
plus while I have them apart im going to powder coat them.
96meangreengt is offline
Old 10-18-2011, 06:41 PM
BraMas
BraMas's Avatar
it is real easy. the price they quoted you is crazy the rubber boots are only $6 @ autozone
http://www.autozone.com/autozone/par...er=228051_0_0_
make sure you lube the o ring up with clean brake fluid when putting the pistons back in
BraMas is offline
Old 10-18-2011, 06:58 PM
Mustangs4U
Mustangs4U's Avatar
I used to work for a brake shop and we would rebuild the calipers by putting paper towels in-between the piston and where the brakes would go. You then, using an air compressor, blow air into the bleeder valve which will pop, and I do mean pop the piston out. Once you do this, you can hone the inside of the caliper and replace the rubbers inside and out. Then push the piston back in, install and bleed.
Oh and like BraMas said, don't forget to put clean brake fluid on the ring before installing the piston back in.
Its pretty easy and cheap too.
Mustangs4U is offline
Old 10-18-2011, 07:21 PM
96meangreengt
ok thanks. yeah it looked like a pretty straightforward process.
My other question is im going to upgrade my brake fluid to at least a dot4. how much fluid does it take to replace all the old fluid. the Motul dot4 fluid is $20 for 17oz and I was hoping it wouldn't take more than 2 bottles.
I will probably do a full writeup on the whole process.
4cylinderplus2
10-09-2020 07:45 PM
baddog671
07-26-2016 01:20 PM
Dathan
10-05-2015 05:52 AM
UrS4
09-30-2015 10:13 AM
marc954
09-29-2015 11:18 AM
Quick Reply: how to rebuild front calipers
