2000 GT Stroker swap
Old 10-21-2011, 02:31 AM
Bahdgt
Bahdgt's Avatar
Question 2000 GT Stroker swap
Hello guys new here and am looking for some advice
My friend is helping me slowly put together a stoker for my 2000 GT. After all is said and done the motor will be pushing about 410 HP, there in lays my problem, will the stock rear end and tranny hold that many ponies and once i upgrade it (moneys running short already in the 8 grand range) to a blower looking around 600-750 HP. So what would you guys think the stock tranny and rear end will take?
P.s i know everyone says why swap the engine over just forge the stock 4.6L 2V and from my experience the stock 4.6L 2V engines were very weak for a V8. I for one cannot see taking an engine that i believe to be cheaply built by ford and fixing it. I can build a much nicer engine that can go FAR beyond what the stock 4.6L 2V and handle it and then some (Plus i can custom paint it and it looks so much better than the ugly volcanic rock V8 i have now)
Bahdgt is offline
Old 10-21-2011, 03:07 PM
school boy
school boy's Avatar
1) you do know when you stroke it, you're only adding a longer crank throw in the stock (or similar block) gt block?
2) what else are you running to make 400rwhp? because those kits really only add 15-20hp
3) might want to consider upgrading to 31 spine axles, diff and a set of gears(3.73 3.90 4.10 or 4.30)
school boy is offline
Old 10-21-2011, 11:48 PM
Bahdgt
Bahdgt's Avatar
Its not a kit its a whole new engine from top to bottom
Bahdgt is offline
Old 10-21-2011, 11:53 PM
Bahdgt
Bahdgt's Avatar
Sorry for double post but heres a parts list
Precision machined 302 roller block
Nodular cast iron crankshaft
Shot peened & stress relieved connecting rods with 190,00 psi hardened bolts
Hypereutectic federal mogul 9.5 to 1 compression
Speed pro chrome Moly piston rings
3 piece steel double roller style timing chain
Hydraulic steel roller camshaft
New Melling oil pump and screen
Edelbrock rpm aluminum heads 60cc combustion chamber with bronze guides
stainless steel swirl polished intake valves
stainless steel swirl polished exhaust valves
Hard seats
Heavy duty 1.45 diameter valve springs, 7 degree locks
Champion spark plugs gapped and installed
Comp cams roller tip rockers
heavy duty chrome Moly push rods
chrome front sump 5 quart oil pan
Timing chain cover with scale
Chrome baffled valve covers
Edelbrock performer rpm dual plane intake manifold
4 barrel 650 cfm Edelbrock avs carburetor with electric choke
Electronic ignition distributor. 1 wire hook-up 45,000 volt coil pak
45 degree water temperature thermostat housing
8mm Accel silicone wires
chrome thermostat housing
New fuel and water pump
Chrome dip tube and dipstick
chrome Moroso air cleaner with pcv ventilation system
New fuel lines and gas filter
so in almost every aspect brand spanking new nearly nothing from fords engine was used
Bahdgt is offline
Old 10-22-2011, 10:27 AM
school boy
school boy's Avatar
thats a pushrod motor used in the 94-95 sn95's and fobody's
Old 10-22-2011, 11:10 AM
ZeroTX
ZeroTX's Avatar
What, you're putting a carbed pushrod motor into a 2000 GT? Have to say I cannot support that, but it's your car
ZeroTX is offline
Old 10-22-2011, 07:56 PM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
its ok, some people are just scared of going fast...
sn95_331_GT_ yellow is offline
Old 10-23-2011, 12:53 AM
school boy
school boy's Avatar
lmao, tell a 03-04 cobra that!
Old 10-23-2011, 01:25 AM
Bahdgt
Bahdgt's Avatar
Because this motors twice that of the stock Cobra or GT motor?
But lets get some opinions building that or,
http://www.fordracingparts.com/parts...tKeyField=9678
(sorry im just assume FordRacing links are allowed, if not please remove and my apologizes)
Bahdgt is offline
Old 10-23-2011, 04:52 PM
RichM1983
RichM1983's Avatar
You have been sorely misinformed about the 2v. If you go with those twisted wedge heads and build the motor right it can make as much HP as a 302. You just MAY be able to build the 302 cheaper.
RichM1983 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Bokeo
10-10-2015 08:28 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: 2000 GT Stroker swap
