New gauges, alternator charge wire lg/rd how to wire?
Old 02-13-2012, 05:00 PM
cisurfer
cisurfer's Avatar
Default New gauges, alternator charge wire lg/rd how to wire?
I'm building my own gauge cluster and removing the stock one. Going to use autometer gauges. I know coming off of the alternator is a lg/rd wire that turns on the voltage regulator and runs through the stock cluster. Im looking at the wiring diagram and it shows a 490 ohm resistor next to the bulb but I can't find a 490 ohm resistor anywhere. How can I wire this lg/rd exciter wire up to charge the alternator?
cisurfer is offline
Old 02-14-2012, 05:36 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
You can use 390Ω and 100Ω resistors, both standard values, in series to create 490Ω resistance.
---/\/\/\390Ω/\/\/\---/\/\/\100Ω/\/\/\--- = 490Ω
This line is used to supply initial power to the field coils, then once the generator begins producing current it is self-exciting. At that point the regulator supplies near 1/2 the regulated output to the light green/red wire, which keeps the indicator lamp off.
If the generator output voltage falls below its proper value the voltage delivered to the lg/rd wire falls, turning the indicator on...
cliffyk is offline
Old 02-14-2012, 01:53 PM
cisurfer
cisurfer's Avatar
Awesome thanks cliff. Didn't think putting them inline would net the same result
cisurfer is offline
Old 02-14-2012, 01:58 PM
cisurfer
cisurfer's Avatar
And I would just connect it to a ign run wire? Do I need any type of diode to prevent back voltage? And would 1/2watt resistors work?
cisurfer is offline
jwog666
12-27-2021 08:09 PM
Dathan
10-05-2015 05:52 AM
lmurf60
09-24-2015 10:07 PM
SteelerNation82
09-16-2015 07:11 AM
rksnow1
09-14-2015 08:46 PM
Quick Reply: New gauges, alternator charge wire lg/rd how to wire?
