piston notch q's
Old 02-20-2012, 03:50 PM
35annGT
35annGT's Avatar
Default piston notch q's
I am wondering if I will need to notch my pistons for the cams I will be running. The pistons are -23cc dish, here is the info from my cam card
Intake/Exhaust
Gross Valve Lift- .500 .500
Cam Lobe Lift- .3000 .3000
Adv, Duration @ .006 Valve Lift 269 269
Intake/ Exhaust
Duration @ .050- 234 234
Thanks
35annGT is offline
Old 02-20-2012, 07:40 PM
zero2005
zero2005's Avatar
there is still a "rim" around the top of the piston where the valve will hit, so notching is necessary still no matter how much dish you run IF you are in the category that needs notching.
see here:
http://www.modularheadshop.com/FAQ/images/notches.jpg
that looks like a pretty radical cam you have there. what exactly is your application?
zero2005 is offline
Old 02-21-2012, 02:04 PM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
whats the LSA* and the ICL*? thats the important info, and just to be safe you better notch them anyways...
sn95_331_GT_ yellow is offline
uberstang1
12-07-2017 07:10 AM
poke68
12-15-2015 06:25 PM
uberstang1
09-20-2015 06:42 PM
degner122
09-16-2015 07:09 AM
EASTIDEE123
09-14-2015 03:52 PM
Quick Reply: piston notch q's
