Something wrong.....
So i ran to the store. About 4 miles away. come back out started the stang, turned on the lights and noticed none of my gauges moved! They just stayed all the way left like i didn't even turn the key. The car started but no gauges?... After about 10-12 seconds they snapped too and looked normal. So anyone ever see or hear of this? Thanks
My first thoughts head toward the battery, the instrument cluster needs 10.5V minimum for its microcontroller to boot up...
Check the battery voltage (between the terminal connectors, not the battery posts) while cranking the engine, and for a while just after it starts--it should not drop below 10.0V.
Also have the battery load tested (high load, 200A or better). Harbor Freight has their 500A load tester on sale for $50; their 100A tester is only $20, not as high a capacity as I would like it's a good tool nonetheless...
I have this same problem except none of the dash lights come on on the bottom of the cluster except the first 4 from the left, has done that since I got the car a little over a 6 months ago with no adverse affects
I have checked all the fuses and everything is good, so either there is a short somewhere or the gauge cluster itself is bad, not sure which though and don't know where to start
Thanks Mr. Knight ill check the battery and go from there.
Jeremy b keep informed on what u come up with and ill do the same. Thanks
Yep, i noticed that this afternoon comming from work. I stopped at the store and set the parking brake. No parking brake light! So we must be in the same boat.
NICE!! Thanks man, ill check that out and let you know what I find. This forum and all of it’s mustang guys are so very helpful. Thanks to everyone that gave there two or three since!
