Blow thru conversion done! Question...
Old 04-10-2012, 04:12 AM
97stanger
97stanger's Avatar
Yeah I talked to my tuner and that's exactly what he said.
97stanger is offline
Old 04-10-2012, 05:32 AM
uberstang1
Chupacabra
uberstang1's Avatar
Originally Posted by 97stanger
I heard that guys have problems when not properly locating your iac. It has to be after the maf, but if setup properly it should idle just fine
Im running a blowthru setup currently and my IAC sensor is still right after my filter on my procharger intake tube, IAC really shouldn't affect the idle it just reports the temperature of the intake charge. Im throwing a power pipe on so I will be relocating mine to the discharge tube before the throttle body and don't anticipate it to effect anything with the tune, but I won't know untill its finished.
uberstang1 is offline
Old 04-10-2012, 05:37 AM
Chris98Gt
Chris98Gt's Avatar
The IAC valve does have alot to do with idle. The IAT is what reports the intake temp.
Chris98Gt is offline
Old 04-10-2012, 05:50 AM
97stanger
97stanger's Avatar
That's what I've always thought as well. I've read about guys having idle problems because they didn't have their iac setup properly, relocated it to after the maf and wala
Old 04-10-2012, 05:54 AM
dwtjr3
dwtjr3's Avatar
Anyone know where i can get that black rubber grommet that that holds the IAC in the pipe? My cracked and warped when the pipes were getting welded
dwtjr3 is offline
Old 04-10-2012, 06:50 AM
97stanger
97stanger's Avatar
Doug that may be a ford part...maybe latemodelresto?
Old 04-10-2012, 08:55 AM
dwtjr3
dwtjr3's Avatar
ill check there thanks
dwtjr3 is offline
Old 04-10-2012, 09:47 AM
uberstang1
Chupacabra
uberstang1's Avatar
Whoops read it wrong, thought u said IAT not IAC
Old 04-10-2012, 04:01 PM
97stanger
97stanger's Avatar
Its all good, I have my IAT mounted in the back of my plenum due to the meth setup
Old 04-11-2012, 06:37 PM
scooter3
scooter3's Avatar
Very nice man. Once that thing is tuned you will notice a huge difference in how the car performs. I would like to hear a video of that BOV.
scooter3 is offline
Quick Reply: Blow thru conversion done! Question...
