Just got a 2004 GT
Old 04-19-2012, 04:47 PM
Ron505
Ron505's Avatar
Congrats! Nice looking ride!
Ron505 is offline
Old 04-20-2012, 10:05 AM
robvandam
robvandam's Avatar
Congrats! Good looking car!
robvandam is offline
Old 04-21-2012, 08:34 AM
MustangHEMIguy
MustangHEMIguy's Avatar
Originally Posted by Photoshopeth
Thanks guys, I noticed it has the original battery, date code is 3k, which I think would make it October 2003. I read somewhere else that the mach 460 noise went away after changing the battery, although it still starts strong.
I think the hissing noise may be coming from the hydroboost, as it changes in volume as I push the brake pedal, and quiets down when warm.
Also just today as I was loading my 93 Bama tune, I noticed the driver power window randomly wouldn't go down, I've used it several times since I bought it, but it kept clicking. I went back a bit ago and it's working perfectly again. So not sure what's going on with it.
Other than that I'm quite happy with it, the dealer replaced the rodent chewed hood insulator pad with a nice fresh one.
FINALLY! Someone who knows what I went through 2 years ago. My window did the same thing after installing my 93Tune and randomly stopped. I don't know what it is about those Bama tunes, but it's gotta go hand in hand.
MustangHEMIguy is offline
Old 04-21-2012, 08:41 AM
3vStang
3vStang's Avatar
Congrats bro
3vStang is offline
Old 04-21-2012, 09:04 AM
JeremyB
JeremyB's Avatar
The window would have nothing to do with the tune, it's directly wired in, mine do that occassionally, just randomly won't go down, after a few seconds they will go. I think it has something to do with the switches but I haven't really looked into it
JeremyB is offline
Old 04-21-2012, 09:49 AM
Photoshopeth
Photoshopeth's Avatar
Yeah the tune wouldn't effect the window, I was just trying to vent the car while waiting for the tune to load is all. I washed the car a day earlier maybe water got into the system.
One question I have is I need to replace the weatherstripping that runs up the driver door mirror area, as I hear a bunch of wind noise and water comes through in a laser wash. My v6 leaked on the passenger side, so I probably didn't notice wind noise as much. What kind of weatherstripping would this be considered, I can't really tell by looking at LMR or Ford Parts.
Photoshopeth is offline
Old 04-21-2012, 10:05 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
The driver's side window "one-touch down" feature is controlled by the GEM (Generic Electronic Module). The GEM has no connection to the PCM, either directly or through the SCP bus, so a tune could not affect it's operation.
However flashing a tune with an ill-behaved flash tool could make the driver's side window, and perhaps other GEM controlled functions go goofy--here's why.
The GEM can be communicated with through the DLC (Data Link Connector, aka OBD2 port) on pin 7, the ISO-9141 protocol K-line.
The K-line supports bi-directional communication, so if the tuning tool were outputting a signal on pin 7 of the DLC, intended or random, it could cause the GEM to behave oddly ("goofy" being the technical term)--while the flash tool is connected. Once it has been unplugged from the DLC the GEM's ISO line is just floating, connected to nothing else.
Note in the above diagram that the RCM and ABS modules can also be communicated via the ISO-9141 protocol; this is possible because each module has it's own unique and addressable ID.
Also, OP, you should never operate anything electrical while flashing a tune as the tuning tool must supply 18V to pin 13 of the DLC while loading the tune. It does this by a "charge pump" DC-to-DC converter make 18V from 12V. These converters can be temperamental with regard to their input voltage and the last thing you want is for that 18V level to drop while flashing the PCM.
cliffyk is offline
Old 04-21-2012, 11:06 PM
Fillerdust
Fillerdust's Avatar
Very nice ride. Hopefully no mice chewed into the wiring or vacuum lines. Big upgrade for sure!
Fillerdust is offline
Old 04-25-2012, 06:28 PM
Photoshopeth
I'm in shock, about two hours ago, an illegal immigrant slammed into the back of me, didn't have license or insurance. Bumper, exhaust pipe and bumper foam is going to need replaced. I've had it for 2 weeks, FML
Old 04-25-2012, 06:39 PM
Soldier GT
Soldier GT's Avatar
Ain't that a bit**! Are you getting any kind of compensation??
Soldier GT is offline
Quick Reply: Just got a 2004 GT
