Swap engine, best idea?
Hey everyone I have a 1998 mustang gt that is quite dead already. Had a small knocking before the starter went also so I'm wondering if a swap is better then to just rebuild the engine and all. There is a lot of crashed mustang gts (sadly) here and most of them are the 99-04 models.
My two questions are
1. Would the 99-04 4.6 engine bolt right up to my auto trans?
2. Could I carry and bolt my current full exhaust to 99-04 headers?
I apologize for annoying anyone cause I'm sure I'm not the first person to ask this but yeah.
If you are going to do a rebuild, make sure to take your time and get a full rebuild kit with everything you will need. It would be wise to get a Chilton manual as it tells you everything you need to know about tearing the motor down and putting it back together and there are quite a few special tools you would need to borrow/rent. I would also get forged stuff if you are going to rebuild. It's only maybe $5-600 more than using stock replacement.
It will bolt right up to the transmission, but you need to make sure your old pressure plate will bolt to the new motor, somewhere between 99-04 there was a change in the flywheel size and the older models were slightly smaller in diameter. You will also need to get the computer from that car or a tuner since this will have the PI(performance improved) heads, cams, and intake. I feel sure everything else should be the same, you may have to get a new belt since the newer motors have a different belt routing and your full exhaust will bolt up fine.
Thank you for the fast and good response. I appreciate it. I think I will just go with a swap then. The only downside is sadly it's not a do it yourself job as I have no tools so this has to be all paid for, taking it to a mechanic and all. Blah. In the bright side the motors go cheap around here and some as a bundle with the transmission included along with the ecu, cluster and such for only 600-1000.
That doesn't sound too bad I suppose, still hurts my wallet at the end. :'( I'll have to go to shops around here to see their prices. Thanks again though Jeremy.
You should see a 30-40 hp gain.I believe somewhere along the line Ford changed the intake during those years.Earlier models had a plastic crossover or something on them which cracked and broke.They switched them to aluminum I believe on the later models.I'm not sure when they made the change.I would find out and get one with the newer intake on it.
Gary Ugarek
63
12-11-2015 02:01 PM
adamfrosceno
08-27-2015 07:40 AM
Gary Ugarek
08-26-2015 08:41 AM
