Dumb Newbie Question...
Old 12-12-2003, 12:51 PM
Patterson
Patterson's Avatar
Default Dumb Newbie Question...
What's really involved in swapping out the bottom end of a 4.6 2V, i.e the crank, rods and pistons? How much downtime would there be to a daily driver, and how much dough will I need? Comparable in cost to a blower?</P>
I'd appreciate any thoughts. I've done about all I can do without pulling the valve covers or the bottom out.</P>
</P>
Patterson is offline
Old 12-12-2003, 02:05 PM
mabguru
mabguru's Avatar
Well a while back I talked to my installers about installing a paxton novi 2000 on my 4.6 2v and they said that would cost about a grand and it would take about 6 hours of down time, without unkown complications. </P>
If you're taking the bottom end out of that engine I would imagine it would have to be down for a few days, about 2-3. Without buying parts I would estimate 500-1000 in labor, but thats a rough estimate I'm not really sure.</P><edited><editID>mabguru</editID><editDate>37967.5039930556</editDate></edited>
mabguru is offline
Old 12-12-2003, 04:55 PM
BLKSTANG9879
BLKSTANG9879's Avatar
HAY WHATS UP.</P>
IT REALLY ALL DEPENDS ON WHAT YOUR CURRENT MOTOR IS. IF IT IS A 96 TO 98 YOU DON'T EVEN WANT TO REDO JUST THE BOTTOM END BECAUSE THE HEADS ARE SO s**tTY. IF THAT IS THE CASE THEN YOU WILL DEFFENTLY WANT TO UP GRADE TO THE NEWER PI HEADS. ABOUT 3 MOUNTHS AGO I BLEW MY MOTOR. IT WAS A 98 4.6. THE NEW MOTOR I GOT IS A 2001 BLOCK WITH THE PI HEADS THAT ARE PORTED AND STAGE 2 CAMS, AND EVERYTHING IS FORGED WITH LOWER COMPRESSION FOR A SUPERCHARGER. THE COMPLETE UPGRADE RAN ME ABOUT 6 GRAND, AND THAT WAS DOING THE WORK MY SELF. IF YOU HAVE A 99 OR NEWER GT. IT WILL BE CHEAPER BECAUSE YOU WILL HAVE THE BLOCK AND THE HEADS.YOU CAN JUST BUY THE ROTATING ASSEMBLY WHICH IS $2500.00 FOR A FORGED SET. WHILE THE MOTOR IS APART YOU SHOULD DEFFENTLY GET THE HEADS PORTED WHICH IS A ROUND $1000. AND THE CAMS AND VALVES ARE AROUND A 1000. IF YOU PLAN ON A SUPERCHAGER IN THE FUTURE. I DEFFENTLY RECOMEND DOING THE BOTTOM END FIRST.</P>
BLKSTANG9879 is offline
Old 12-20-2003, 02:04 AM
Patterson
Patterson's Avatar
Thanks for the info. I have a 2003 GT, so the heads are good. I'm really not too unhappy with the cam - yet.</P>
I've been talking to MuscleMotors about a 5.1 stroker shortblock - probably once the tax return hits!</P>
Old 12-20-2003, 02:34 AM
Snydaleid
Snydaleid's Avatar
For my rebuild Labor cost me $730not includingtax. My engine was in the machine shop for a few months. I also told them that I wasn't in ahurry either. I can't imagine only having it in there for a few days. I wouldn't assume it would only take a few days I'd ask first. Also make sure whoever you take your engine to knows how to work on mod motors.</P>
Snydaleid is offline
Brett Ludlow
09-23-2015 06:59 AM
toastintx64
08-29-2015 05:12 PM
Calizic
08-28-2015 01:46 PM
Quick Reply: Dumb Newbie Question...
