Headers for a 96GT with PI head swap
Old 06-10-2012, 12:11 AM
infine0n
infine0n's Avatar
Default Headers for a 96GT with PI head swap
Hello,
I am in the process of doing the PI head and intake manifold swap to a 96GT.
I noticed my oil pan is running thin, so in order to change that I know I have to drop the K-member a bit and lift the engine to change the pan. I figure if I'm going this far, I might as well throw some headers on the car.
I know it has aftermarket exhaust on it already. I believe it runs from the manifolds to an H pipe, then it goes into some flowmasters, but I'm not exactly sure what brand.
Anyway, I'm just wondering which headers would be best for my setup, considering it is a 96GT with 04GT heads.. I want it to bolt in and fit perfect. I don't want to spend and arm and a leg on them either.
Any suggestions?
Thanks!
infine0n is offline
Old 06-10-2012, 05:46 AM
uberstang1
Chupacabra
uberstang1's Avatar
Is your car an auto or manual, big difference when it comes to long tubes.
uberstang1 is offline
Old 06-10-2012, 11:32 AM
infine0n
infine0n's Avatar
it is a manual. I just want to make sure they would clear and bolt up to the 2004 heads in a 96 body. have any suggestions?
Thanks
infine0n is offline
Old 06-10-2012, 11:33 AM
uberstang1
Chupacabra
uberstang1's Avatar
Thanks
the physical dimension of the heads are the same, it doesn't matter what heads are on it the headers will fit just the same.
Old 06-11-2012, 04:48 PM
infine0n
infine0n's Avatar
Alright I will look for some decent long tube headers. What do you think about the BBKs?
infine0n is offline
Old 06-11-2012, 05:07 PM
infine0n
infine0n's Avatar
http://chicago.craigslist.org/nwc/pts/3070070929.html
I found these used BBK Long Tubes for $250...
infine0n is offline
Old 06-11-2012, 06:05 PM
madjimmax
madjimmax's Avatar
I have them same ones and they are pretty decent, and with that price you really cant go wrong
madjimmax is offline
Old 06-11-2012, 07:22 PM
infine0n
infine0n's Avatar
That is what I was thinking. I plan to pick them up on Wednesday. I think the only other part I really need right now is an oil pan. I can't seem to find a stock one on eBay (a couple used ones, but I'm afraid they might be running thin like mine is), probably just pick one up from advance auto?
infine0n is offline
Old 06-12-2012, 06:41 PM
disposablehero27
disposablehero27's Avatar
just keep in mind not all headers will allow you to pull the trans without pulling the headers, consequently making you do this job again, or half of it, every time you need to replace that clutch you burnt up on the strip, or that trans that can't hold your f-series procharger tq 10 years down the road. I went with kooks, trans drops in and out. Still not easy, but they will not fit in your "not an arm and a leg" catagory. I've called bbk and many others, and have told me they will not allow the trans to be removed without moving headers first. If you haven't done headers yet, once you have, you will see why i'm posting this.
disposablehero27 is offline
Old 06-13-2012, 03:51 PM
infine0n
infine0n's Avatar
Thanks for the info..but this is all I am planning to do for this car. I might do the gears in the future, but the clutch seems pretty good for right now. I'm not sure how long I will have the car, but probably no more than 2 seasons of summer only.
infine0n is offline
degner122
09-16-2015 07:09 AM
Daddys Girls GTs
09-14-2015 08:46 PM
BrantleyS550
09-14-2015 04:18 PM
EASTIDEE123
09-14-2015 03:52 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: Headers for a 96GT with PI head swap
