P0420, P0721 and P0174 - catalyst, too lean and output shaft speed sensor
I just diagnosed the check engine lamp with my Diablosport Predator Tuner and my 2000 GT 5-speed is throwing several codes:
P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
I am thinking this might be caused by the cats on my Bassani X pipe being too weak? What else do you think would cause this?
P0721 - Output Shaft Speed Sensor Range / Performance
I am thinking this is being caused by my speedo recal that the previous owner installed after installing the 3:73 gears? What else would cause this?
P0174 - System Too Lean (Bank 2)
I have no idea what would cause this. This one scares me.
P1000 - OBD System Readiness Test Not Complete
No idea what would cause this?
Any clues would be highly appreciated.
Where it's just one bank I would first check for exhaust leaks before or near the sensor, or wiring problems/bad sensor (they tell the PCM the mix is lean when they fail).
trashxtrash
09-20-2015 10:49 PM
TfcCDR
09-14-2015 12:08 PM
