Vibration - Motor, trans, driveshaft, wheels what is it?
Old 08-01-2012, 10:39 AM
ElGuapo
ElGuapo's Avatar
Default Vibration - Motor, trans, driveshaft, wheels what is it?
Car is a 1997 Mustang Cobra, 79k miles.
I've noticed that at certain RPM's there's a vibration, you can't really feel it int he car very much but you can watch the shifter shake wildly and it makes a weird noise. It can happen between 2-3k rpm, light throttle, low speeds, but I've noticed it can happen when coasting in gear in high or low revs, 5-5.5k or so.
I've done enough research but haven't really pinpointed anyone that has the same symptoms, I don't know if it's the engine causing the driveline to shake or it's the other way around.
U joints, motor/tranny mounts, wheels unbalanced I dont know what it is. It seems that in neutral or with the clutch pushed in I don't feel or see any of these vibrations. Someone suggseted a loose exhaust clamp but I don't see how that would cause the shifter to shake wildly.
Thanks for any suggestions.
ElGuapo is offline
Old 08-01-2012, 06:19 PM
devongarver
devongarver's Avatar
Might not be a bad idea to start with the drive shaft and U-Joints as prime suspects. The main reason I say this is because you mention the second RPM range, and it not exhibiting the same symptoms while in neutral. Think harmonics here.
devongarver is offline
Old 08-01-2012, 09:39 PM
school boy
school boy's Avatar
if you can get the car in the air, start with the drive shaft to see if there is any play, check trans mount, control arms, ect. with a 97, things are bound to be worn and broken down. these cars have rubber bushings that can deteriorate over time. like mentioned above, the drive shaft sounds like the suspect though
school boy is offline
Old 08-02-2012, 07:20 AM
uberstang1
Chupacabra
uberstang1's Avatar
Im leaning towards driveshaft, but all the things you posted are what to check out.
uberstang1 is offline
Old 08-02-2012, 08:51 AM
ElGuapo
ElGuapo's Avatar
Thanks guys, was hoping it wasn't engine related and doesn't seem like it is then, motor doesn't smoke, no leaks of any kind nothing weird out the tailpipe or smells. I'll do some more digging.
ElGuapo is offline
Tivo304
08-28-2023 12:19 PM
Granatelli Sales
01-20-2020 12:34 AM
97SN95GT
09-13-2015 09:45 PM
raleigh05GTO
09-04-2015 07:09 AM
Luke9222
09-04-2015 06:46 AM
Quick Reply: Vibration - Motor, trans, driveshaft, wheels what is it?
