Aftermarket gear noise
Old 10-23-2012, 04:19 PM
AMWill
Former Sponsor
AMWill's Avatar
Not that helps you any, but I would agree with the improper gear install theory. Usually once the gears really seat, they are "married" together and you shouldn't replace one of the two (ring & pinion) without replacing the other. In your case, they seated improperly and probably need to be completely replaced.
I know you only have 24 posts, but I see you're really suck in a bad situation. So, if you want to shoot me a PM, I'll give you a discount code to use for purchasing new gears at AM! I figure every little bit will help!
Shane
AMWill is offline
KingRando
10-01-2015 11:16 AM
allenmaty
09-24-2015 09:17 AM
stealth_GT
The Racers Bench
09-22-2015 02:19 PM
ccdguy
09-19-2015 05:20 PM
Quick Reply: Aftermarket gear noise
