Suspension setup for street/strip
Old 11-30-2012, 09:10 AM
Muddytoy
Muddytoy's Avatar
Default Suspension setup for street/strip
Hey guys I dont have a ton of money to spend on this but I was thinking if I lowered the front about 1-1.5'' and left the rear alone it will have that raked out stance. I did 265/45/16 in the rear with the Track/Street tires and leaving the 225/55/16 in the front. I am doing sub frame connectors as its a convertible. I have the front strut bar brace and am building a rear one as I cant find one for a 1998. Any idea if this would be a ok setup?
Muddytoy is offline
Old 11-30-2012, 10:23 AM
xx10Gt
xx10Gt's Avatar
Some UCA's and LCA's probably wouldnt hurt to get the power to the ground
xx10Gt is offline
Old 11-30-2012, 11:13 AM
Muddytoy
Muddytoy's Avatar
So the upper and lowers are no good stock?
Muddytoy is offline
Old 11-30-2012, 11:20 AM
Muddytoy
Muddytoy's Avatar
Ah after some google'ing I see the rear arms like to flex, I found some nice tubular upgrades for 175 bucks. I will add them to the list!
Muddytoy is offline
Old 11-30-2012, 01:49 PM
BraMas
BraMas's Avatar
"raked out stance"? It's 2012 not 1980
Or is this awful trend coming back?
BraMas is offline
Old 11-30-2012, 02:07 PM
Muddytoy
Muddytoy's Avatar
Well I am buiding it to be a street strip car not a car for back roads and road course racing, so I figured having the rear up a little higher will help with launching at the track. This is not an import so I dont see the need to slam the whole car.
Muddytoy is offline
Old 11-30-2012, 02:37 PM
uberstang1
Chupacabra
uberstang1's Avatar
Theres one thing highley overlooked here, by slamming the front end ONLY ur adding some way bad pinion angle which isn't good for hooking up at the track. IDEALLY if leave stock springs all the way around and run solid lowers and adjustable uppers, dial it in for -2 pinion angle, run a good adjustable shock like the strange10 ways all the way around and a big sidewall tire for traction and to fill the wheel wells. Best bang for the dollar.
uberstang1 is offline
Matt's 95 Stang
10-05-2015 07:16 AM
fastbackford351
10-01-2015 12:24 PM
guitarman376
09-30-2015 05:54 PM
Drastang
09-29-2015 03:31 PM
marc954
09-29-2015 11:18 AM
Quick Reply: Suspension setup for street/strip
