Weird grind noise in 5th gear
Old 01-12-2013, 09:49 PM
The Green Lantern
The Green Lantern's Avatar
Default Weird grind noise in 5th gear
I've got a 40th edition GT with the tr3650, just got a new clutch put(exedy mach 350 kit) in and now its making this awful grinding noise while in 5th gear. Car seems to accelerate and be just fine but just makes awful noise. When I take it out of 5th it will do it sometimes while in neutral. I've read it might just be these loud tremecs that do that, but want to see yalls opinions.
Thank you
The Green Lantern is offline
Old 01-12-2013, 10:04 PM
jrp1588
jrp1588's Avatar
I've had two mustangs, both with tr3650's, and both were a little noisey in 5th. I wouldn't describe it as a grinding at all though. It also sounds like it didn't make this noise before, so that's certainly cause for concern.
jrp1588 is offline
Old 01-12-2013, 11:54 PM
The Green Lantern
Well yeah its not the obvious gear grind but it is kind of similar to that, but yes it was NOT doing it before with the older clutch. It was a ram stage 2 clutch.
Old 01-20-2013, 06:44 PM
tracyballard
tracyballard's Avatar
is it a constant steady noise, or an intermittent noise? Can you feel it through the shifter more than you can hear it?
tracyballard is offline
Old 01-22-2013, 09:21 AM
TheWhiteStain
TheWhiteStain's Avatar
In my mach 5th has a Whine noise.. But nothing like grinding.. Is it more of an ambient noise that could just be the gears working? Or worse... Record a vid or sound clip mabye.
TheWhiteStain is offline
KingRando
10-01-2015 11:16 AM
foxdude
09-24-2015 08:45 PM
musnicki
09-23-2015 07:11 AM
ccdguy
09-19-2015 05:20 PM
Quick Reply: Weird grind noise in 5th gear
