Belt tensioner
Old 01-23-2013, 08:00 PM
slick66stang
slick66stang's Avatar
Default Belt tensioner
My tensioner is chirping when the car gets warmed up, how hard is it to replace the tensioner
slick66stang is offline
Old 01-23-2013, 08:05 PM
Special20
Special20's Avatar
Very easy. One bolt if I remember correctly. Take the belt off, unbolt tensioner, replace with new one, and put belt back on. It might be a good time to replace belt also.- Good luck
Special20 is offline
Old 01-24-2013, 04:46 AM
petrock
petrock's Avatar
It is super easy. Are you sure its not the tensioner pulley and not the entire tensioner itself that is making the noise? The pulley is a lot cheaper and easier to replace then the entire tensioner, even though both are relatively easy. Check out rockauto.com for a new pulley. If memory serves, the pulleys mounting bolt is reverse threads.
If your belt has more then 60k miles on it, it might be a good time to replace it too while your at it.
petrock is offline
Old 01-24-2013, 08:40 AM
uberstang1
Chupacabra
uberstang1's Avatar
Might be your belt
uberstang1 is offline
Old 01-24-2013, 11:48 AM
slick66stang
My belt is new and only has 100 miles on it. I noticed there was some oil and coolant on the belt from where I had a leak when I pressure washed it. I'll replace my belt and then the tensioner if it don't st.op
Old 01-24-2013, 12:35 PM
uberstang1
Chupacabra
uberstang1's Avatar
Just an FYI alot of companies are switching to kevlar construction belts, if they get antifreeze on them they will make noise for ever.
vargas
06-17-2017 12:17 PM
FivePointToTheOh
09-29-2015 12:53 PM
MacSerio
09-27-2015 01:05 PM
rafotree
09-22-2015 03:55 PM
Quick Reply: Belt tensioner
